Where can I buy a RAG steering joint?
Car: Firebird 1987
Engine: 5.0
Can anyone tell me where I can buy a RAG steering joint, either original with the rubber disc, or the metal lockup type? My car is an '87 Firebird.
A company that will sell online would be good as I am in the UK.
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Re: Where can I buy a RAG steering joint?
Check the following site as well; someone might have one in the UK:
http://www.pistonheads.com/gassing/
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Two new ones on ebay. I bouhgt one from this person about two months ago and was great.
http://cgi.ebay.com/ebaymotors/Camar...mZ330164692196
http://cgi.ebay.com/ebaymotors/Camar...mZ330164699030
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You can get a metal rag-joint eliminator from here:
http://www.unbalancedengineering.com...Rag_Joint_3rd/
The pic is my car that has one installed.
Car: Firebird 1987
Engine: 5.0
Thanks for the replies. I actually looked on Ebay, but for some reason it didn't find the ones above.
I like the sound of the metal one, however I read somewhere on here, about someone who fitted a metal joint and was slightly worried that the column and the input shaft to the steering box may not be dead in line. He had fitted the joint and found that on a full roatation of the steering wheel that it seemed to get a little tighter in one part of the revolution. Have you found anything like that?
I also read from someone else that the column and steering box were designed to be absolutely in line, and that it wasn't anything to worrk about.
What do you think?
What do you think?
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
