can't find the tire size i want. help
Old Sep 11, 2007 | 11:02 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
i've been looking to put 255/50 in the front and 265 or 275 50 in the rear on ta 84 T/A with 16x8 factory wheels.
my problem is i can't find 265 or 275 50's. did they stop making these sizes?
i don't want 17"rims and i don't a 45 aspect tire.
can ya's help me out.
thanks. jay.
Old Sep 12, 2007 | 09:21 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: can't find the tire size i want. help
Most poeple are putting the P245/50R16 on the front and P255/50R16s on the rear. A 265 or 275/50R16 will be too big in Diameter to work correctly on the rear. You need to think about this again. The P275/50R16 tire size is not in my Tire & Rim book. If you could find it, a P275/45R16 would be about the right diamteter, but its not in my book either and is too wide for 8" wide wheels anyway.
Old Sep 12, 2007 | 10:30 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
275 is not to wide for 8" rim i had them on my stock 17x8 mustang wheels when i had it. and had no issues with rollover or the contact patch.drove it like that for 2 years. it was a 2000 gt. however a 50mm side wall might be to much,but not with a 45 series tire. (45 meaning sidewall hieght)
i would never go anymore than 275 on a 8". that is the max. but ur right with a 275/50,u might be more prone to the tire rolling over than u would with a 45 series. u would def have the contact patch compromised.
but with this car i don't want a 45 aspect even if i could get it.i don't want 17" rims either.i don't think the 45'st look good on these bodies. not enough side wall,so the 275 would be out.
now about the 255 in the front. i thought i saw poeple on here that were running them,but i can't remember if they were rubbing lock to lock. if it would then i would go 245 front and 255 rear.
thanks for ur reply.
Old Sep 12, 2007 | 10:31 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Basically the same thing seems to be happening to 16" size choices,with the 17" & 18" becoming more common,as happened to 15" choices as 16" became more widely used.Then you have to take into account safe fitment on the wheel size,overall diameter unless you change speedometer gears and tire scrub front and rear - all of this as noted by Doc.
Old Sep 13, 2007 | 12:54 AM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
true.but to say that a 275 will not be safe on an 8" rim is giving false info. even a 16x8 rim could handle a 275mm tire as long as u go down in aspect from 50 to 45 and the contact patch will remain unchanged. anything more than 275 on a 8" rim i would worry.
Old Sep 19, 2007 | 06:46 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
WS6, if you would see the footprint of a 275 on an 8" wide wheel VS a 9.5" wide wheel, you would not be saying what you said. You dont know it, but you ran mostly on the center 3 ribs!
Old Sep 19, 2007 | 10:47 PM
L69HAWK's Avatar
Car: 1984 T/A WS6
Engine: L69 305
yeah ur prolly right,but it does fit lol.
thats allright doc i'll be going with the 255's or 265's if i can find them.
thanks alot.
jay.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
