Picture of a mounted edelbroc STB bracket on strut tower
Old Sep 21, 2007 | 11:24 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
anyone got a closeup of how they mountThanks.
Old Sep 22, 2007 | 06:41 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Picture of a mounted edelbroc STB bracket on strut tower
About as close up as I have, the bar mounts too 2 "U" shaped brackets that have 2 holes you drill thru the strut tower in front of the strut mount, the cowl mount needs two holes drilled too and it sandwichs the lip of the cowl when bolted.
Old Sep 22, 2007 | 10:47 AM
Jproz1167's Avatar
Thanks .... I had thought maybe one bolt that is on the strut tower secures the braces. But basically you just drill two holes in the strut tower right?
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Genopsyde
Nov 11, 2015 10:46 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
