Cragar SS wheels on 1990 RS
Do Cragar SS wheels bolt onto third gens without spacers? I have the stock 15 x 7 starfish aluminum wheels with 215 65 15 tires. Also my 90 RS has stock front disc and rear drum brakes. Has anyone tried these wheels, if yes what is the part number and specs like backspacing and lug nut specs and stuff.
Re: Cragar SS wheels on 1990 RS
The bolt pattern is 5 x 4.75. Most aftermarket wheels made for thirdgens use 4.5" backspacing with 0 offset. From the factory, the front and rear have slightly different offset, but when you use the same ones, you can rotate them any way you want without a problem.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
