rack and pinion (yes another one)
Old Oct 10, 2007 | 08:10 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
okay i did the search and none of then seemed to answer my questions. Does anyone make a bolt on type kit conversion for the 3rd gen?
either way shoot me some sites that have them
(i know hawks has em)
and i prefer power rack, thanks!!
Old Oct 11, 2007 | 07:02 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: rack and pinion (yes another one)
i think the only way i've seen work is to get the tubular K-member with the rack mounts. i think PA Racing, AJE, and Spohn offer them. a rack from a late 70's mustang will work with mods to the tie rod ends.......checkout the k-member threads....
Old Oct 11, 2007 | 12:51 PM
ryan91rs's Avatar
Transmission: 4L60
i was just wondering b/c when i had my el Camino there was a bolt on kit that had everything you need (and it was a power rack) it seems the f body has less options then the g body.
Old Oct 14, 2007 | 12:41 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Check out Flaming River
Old Oct 15, 2007 | 07:01 PM
ryan91rs's Avatar
Transmission: 4L60
there is nothing for the 3rd gens but can a different one be retrofitted with their mounting clamps?
Old Oct 19, 2007 | 01:43 PM
Shagwell's Avatar
Car: projects.......
There is only one rack out there that has enough travel to allow full turning in our cars. If you search, you can find it, but I don't believe it's available power.
Over all, there is not enough benefit of converting, plus, there's a very low demand. Minimal weight loss and usually a substantial loss of turning radius. The k-members that allow the use of a pinto rack or a mustange rack will cost you about 1/2 your turning radius. You have to remember, most of the tube k-members are designed for straight-line applications.
Ed1LE
Sep 30, 2018 09:14 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
dimented24x7
Sep 17, 2015 06:58 AM
