Should I change rear bump stops?
Old Oct 15, 2007 | 10:09 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I have had a set of rear dropzone springs on my Camaro for a couple of years now. The ride has always been a little harsh, but the other day I stumbled across a few threads on different options on bump stops. At ride height, I have about 7/8" clearance between the bump stop and the axle. I know the bump stop hits the axle due to how clean it is. Most people have talked about changing bump stops for auto cross reasons; however, would they benefit me as well?
Old Oct 15, 2007 | 11:55 PM
Duracell Bunny's Avatar
Re: Should I change rear bump stops?
The factory bump stops are hard as heil. When you contact them, they have about a 1/4" give and snaps you into oversteer when the travel is limited abruptly.
You can take them off and shave them down with a good taper on the sides to get more clearance AND a softer contact progression.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
jklein337
Sep 19, 2018 06:23 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
