36mm poly bushings?
Old Oct 16, 2007 | 08:25 AM
Stephen's Avatar
Car: 87 GTA
36mm poly bushings?
Biggest I can find is 1 1/4", but a 36mm bar is just under 1 3/8". Almost 1/8 over the biggest listed.
Just use a bushing that is oversized....undersized,,,,or undersized, and slightly "ground out" to fit closer?
Old Oct 16, 2007 | 08:33 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: 36mm poly bushings?
I got my 36mm bushings from Spohn. They are black polyurathane and greasable.
Old Oct 16, 2007 | 08:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Another board sponsor, TDS, carries them as well.
JamesC
Old Oct 16, 2007 | 09:22 AM
Or, http://store.summitracing.com/partde...P%2D7%2D1168BL
Old Oct 16, 2007 | 09:46 AM
Stephen's Avatar
Car: 87 GTA
Thanks. Dunno why I couldn't find them on the Summit site.
I swapped out my rear GTA wheels for a front pair, so I'm now running 4 front wheels. Certainly looks better, withe the shallower backspacing.
Anyways, looking at my rear bushings, my bet is they are 20 years old. My bet is the fronts are no better. I'm thinking of getting new bushings & end links, front & rear.
Old Oct 16, 2007 | 09:58 AM
Do it... you'll be glad you did. Amazing difference for not much $$$.
Old Oct 16, 2007 | 10:30 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Bushings are a big help. Little noisy, but I don't mind...until people look at my car like somethings broken instead of done right.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
