Car jerks around when backing up and turning
Old Nov 7, 2007 | 01:03 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
What is the cause of this? I had the car aligned a while ago but it did not help. Two of my three have done his when backing up. I had an old guy looking to see if something was broken when I backed up by him, it was almost hopping and creaking so much. The front end was redone by last owner about 14,000 miles ago. I did also swap the struts from the old car.
Old Nov 7, 2007 | 01:51 PM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
Re: Car jerks around when backing up and turning
does the car hop around any other time or only when you are turning and backing up? Is it turn direction specific? Is it coming from the front or back of the car?
Old Nov 7, 2007 | 08:44 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
It only happens when backing, definately from the front. I have only noticed it when backing to the right, but I will try the other way in the morning to be sure. The car darts around on grooved roads which some people have said is normal from wide tires and others I have read said that it is ball joints. The inner tire on the driver's side is slightly more worn, but that could be from the drama of backing up.
Old Nov 7, 2007 | 09:08 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
ya they dart around on grooved pavement a bit (scared the living crap out of me the first time that happened, i live near a truck stop and they have grooves so deep you can see them from two intersections away)
that sounds weird, only when backing up. all i can think of is the front brakes are messed up. i know not much help
Old Nov 7, 2007 | 09:17 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Are the wheels cut all the way when it happens? I think its normal to a certain extent, things get pretty crazy with these cars when the wheels are turned all the way.
Old Nov 8, 2007 | 07:35 AM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
It really seems suspension related. The wheel is just barely turned and it starts to do it, if I did full lock I feel like the wheels would snap off. It does do it both ways.
Old Nov 8, 2007 | 07:53 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Check the lower control arm to K member bushings. Worn bushings will cause your issues.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Kaweh
Aug 9, 2015 02:54 PM
Fronzizzle
Aug 9, 2015 01:15 PM
