Need help with offset and backspacing.
Old Nov 7, 2007 | 06:59 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Engine: 350 4-Bolt Main
Transmission: Rebuilt 700R-4
Axle/Gears: 3:42
ok i am lookin at a set of american racing wheels.i have a 86 iroc and i am wanting to go with 17X9 in the front and 18X9 in the rear. what would be the ideal offset and backspacing for these wheels on my car?
Old Nov 7, 2007 | 11:53 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Re: Need help with offset and backspacing.
5.5" backspace in front, and 5" bs rear.
You may want to consider 8" wide rims up front as wider rim/tires don't fit that great (will rub near steering locks).
If you go with an 8" up front rim use 4.5" backspace
Old Nov 8, 2007 | 12:41 AM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
the wheels that i am looking at shows they only come like with these specs for 5 on 4 3/4 bolt pattern:
17X8 - 5 7/8" B.S
18X8.5 - 6 1/8" B.S
i am also lookin at another set that would be my second choice the specs on them are:
17X7.5 - 5 3/4" B.S
18X9 - 6" B.S
would either of these wheels work or am i going to have an problems with them as far a direct bolt on? thanks in advance for any help!!
Old Nov 8, 2007 | 11:20 AM
Car: 88 camaro
Engine: 355
Anything different that what I posted will pretty much require a spacer
17x8 front with 5 7/8 needs 1 1/8 spacer
18x 8.5 rear with 6 1/8"bs will need 1 5/8" spacer
other ones need spacers too
Old Nov 8, 2007 | 01:44 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
ok thanks for clearing that up for me! where can i get these spacers at and how much are they?
Old Nov 8, 2007 | 11:51 PM
Car: 88 camaro
Engine: 355
The technical term is actually adapter.
A spacer is really only good for max 1/4" because of thread engagement. An adapter will bolt to your hub and has another set of bolts that your wheel will bolt to. Go to skulte.com, that's the best place to get them. You can also learn about backspacing and adapters on his site.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
rb85TA
26
Sep 14, 2015 10:29 PM
