suspension noises
Old Nov 13, 2007 | 02:39 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
suspension noises
so when im driving and i hit a speed bump, etc. i keep hearing a weird clanking noise. like chains. the guy i bought the beast from said the suspension bushings need a change...??? and when I cut the wheel to the far right i.e. parking; it makes a popping thudding sound...but the tires are clear of any fender wall etc. so I dunno anyone got any input for this?? thanks.
Old Nov 17, 2007 | 02:47 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: suspension noises
That sounds like your upper strut mounts. I replaced mine with ones from the Zone and had to replace them again with HotPart ones about a year later. I'd go ahead and replace them with Spohn or HotPart pieces. Also, you'll need to check your ball joints, sway bar end links and bushings, tie rod ends....
Old Nov 17, 2007 | 03:22 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i would start with the easy fix 1st. sway bar bushings and end links. fixed me up. just make sure you order the right size bushing since there are 3 different sizes for the front.
Old Nov 17, 2007 | 05:30 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
i second the sway bar endlinks... could be the strut/ball joint tho.
lift the front and see if u can wiggle the wheel by pulling and pushing the top and bottom of the wheel, of course look at the sway bar endlinks, and check the strut.
Old Nov 17, 2007 | 05:59 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I think that they're more than 3 sizes on the front sway bar. 4 or 5 I think.
Old Nov 18, 2007 | 05:27 PM
frirebird952's Avatar
Car: 86 ta ws6 silver and gun metal
Engine: 305 fi lb9 eng code f
Transmission: 700 r4 with shift kit
Axle/Gears: lim slip not sure gears
i have a sim noise it makes noise like chains in rear it also makes a rubbing sound kinda metal sounding it only does it at 5 mph or less no vibe at high speeds forward or reverse not matter does it in both have changed my wheels no help cant find anything loose under there any help would be ap
Old Nov 27, 2007 | 01:39 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
if i hit some rail road tracks doing the 55 speed limit i hear a loud right thuding noise like i just bottomed out, but i just put new shocks, rims, tires, rotors, brakes on :/
LT1Formula
Oct 8, 2015 08:34 PM
sjorgens
Oct 1, 2015 07:54 PM
