Eibach Springs
Eibach Springs
I was wondering if anyone has any before and after pictures they could post in this thread of an 82-92 firebird without a body kit (non-trans or gta) with either Eibach Pros or Eibach Sportlines.
Just wanna get an idea of what they are going to look like..whether or not I should go for the 1 inch pros, or drop it even more with the sportlines.
I know the Sportlines have a lower drop in the front springs. I want the front to have a lower stance, but I also dont want a shovel for a car.(My city roads were built for off-roading) Im being just a little sarcastic, but i do come across alot of steep driveways. I'm pretty sure with the 1 inch front and rear drop, the front end still has a lower stance.
But pictures speak for themselves.
and if I happen to miss a thread with these pictures already, fill me in!
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Eibach Springs
I'm going to warn against Sportlines. They lower the car more than the Pro-Kit and they are softer. This combination leads to (and Eibach admits to designing them this way) riding on the bumpstops or at least using them as a supplement for the springs. This can lead to snap over- or under-steer. Some people on this forum report that they don't hit the bumpstops, but I don't see this being a common occurance.
Whatever spring you choose, be sure to get new shocks that are designed to work with lower springs. Otherwise, the car will ride and handle poorly.
Car: 1991 RS Camaro
Re: Eibach Springs
If you have the extra money, you might want to look into a set of Ground Control Weight Jacks. You can adjust the rid height as you see fit and get a good set of springs with it. You'll just need to get a front alignment everytime you adjust it. haha
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Eibach Springs
i got the sportlines and i believe there was a post on it.... do a search. i showed pics of every point int he process, i love the look its nuts how well they look, the sportlines have 1.6" drop front and 1.3" rear... prob alil more dpending where and how old ur springs are, might even lift it.... i have maybe an inch of fender gap in the front. the prokit doesnt get rid of the stock *** draggin stance bc its a uniform lowering of 1" front and rear. the prokit has stiffer rear springs but the fronts are really close.
sportlines are
700lb front
130 progressive rear
prokit
715front
160rear i believe.
its a low drop with the sportlines and i scrap my air damn getting in and outa some steep driveways and i cant get a jack under my car lol, i gotta use a low profile aluminum one. and i had to get my car aligned at a sports car (ferrari/vette/porshe) place bc its too low for most shops to do. but its all worth the performance and looks!!!
first pic is stock 120,000 ws6 springs stock struts/shocks
2nd+3rd are sportlines, Kyb shocks/struts, poly front control arm bushings
i have posted better pics do a search of my name in suspension, they have dropped alil since then especially in the rear, i believe i havent hit the bumpstops either and thats in NJ home of potholes
sportlines are
700lb front
prokit
715front
160rear i believe.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Eibach Springs
ive never had any issues with my sportlines bottoming out, though i will say that they do not play well with a lakewood bellhousing
Re: Eibach Springs
Thanks for the input guys.
Blackbird.. thats for your input and photos, just what i was looking for.. You dont happen to have a photo with your Eibachs on at the same angle as the stock photo do you?
Thanks.
Thanks.
Re: Eibach Springs
i have sportlines on my car and i would recomend them but not if your ONLY doing the springs. i would upgrade the shocks and struts to something a little better matched to the springs and if you dont have the biggest sway bars on the car get them.... that will help ALOT with the bump stop problem...unless you drive 100 plus and hit a dip then its your fault.....lol. i put my sportlines on and it was almost not even noticable from the stock iroc springs in ride height since the stocks were sagging so bad. and i never bottomed out on the sagging 550lb iroc springs. i dont see a 700lb spring doing it then. i would post pics but some of you have seen them before and i have the problemed spohn a arms on and dropped the front ALOT... and havent corected the problem yet so the pic wont help you out.
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Eibach Springs
stock height (with moroso 220in/lbs front springs) about a 1/2 inch drop up front
after with sportlines
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Re: Eibach Springs
just an FYI for those that posted pictures d arker cars taking a picture in the shadows and trying to show the gap between them isn't helping on my monitor
Re: Eibach Springs
Thanks 5678TA! Thats just what I was looking for. See the sportlines aren't so bad on a bird with no body kit, looks real nice. I think thats what ill go for!
What size rim do you have in the last photo? (in the front)
Thanks again!
Thanks again!
Car: 87 TA clone
Re: Eibach Springs
i could find some more if you still wanna see them, the cars without grond efects look really good with sportlines.
rx7speed... lol im sorry my driveway is just wide enough for the car let alone me and my camera, i have others of it on the street if u want.
on a side note the shadows make it look sexxxxxxxxyyyyyyyyyy!
Car: 86 Trans Am
Re: Eibach Springs
i dont know, but in the second pic, it looks like you drove over Santa
Car: 87 TA clone
Re: Eibach Springs
they have settled alil more since then, but the rear could have been dropped another 1/2" if i took out the stock rubber spacer in the rear and switched to rubber cooling hose. hope it helps
and yes i kno i have a key mark and yellow spots on the front bumber! sum jack arss backed into my parked car
Car: 1987 Firebird
Engine: 355
Re: Eibach Springs
Damn key marks suck. Didnt notice the yellow, dont worry though i got some too. It does not hinder the performance one bit
How are speed bumps treating you custom?
.How are speed bumps treating you custom?
Car: 1984 Trans Am
Re: Eibach Springs
here's another one i found
Car: 87 TA clone
Re: Eibach Springs
yea i kno, i did all the body work on the street just how it is for 2 weeks, and got a fresh coat of black with 2 coats of clear (car was blue originally) and after 3 months someone keyed it 5 houses down from mine the entire driver side!! AUGH!!! then the bump was a few months later infront of my house. the paints only alil over a year old
this is true about the yellow spots i havent noticed much power drop lol, i dont thinkt he painter put in the flex additive when he painted the front/rear bumpers.
speedbumps suckkkkk! ha not that bad if i go on an angle and turn the car off and barely roll over it lol.jk really it isnt that bad its my true duals that are killin me with the sportlines. i havent been able to cut into the floor to tuck the mufflers up but the rest has been knotched to the floor and doesnt sit lower than my deep trans pan.
online170 i believe ur saturn has a 1.6/1.8 or 2L 4 banger lol thats just want to much power for me. i loved workin on saturns prob the easiest to work on, ive done a few front strut installs etc on them, loved it, it was cake
Last edited by customblackbird; Nov 19, 2007 at 05:06 AM. Reason: Automerged Doublepost
LT1Formula
Oct 8, 2015 08:34 PM
