power to manual steering
Old Dec 3, 2007 | 12:03 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
the power steering pump is going on the camaro i just bought to turn into a strip car and i want to get manual steering.
the only solution i have found is a manual rack for ~$600 from several places, is there a cheaper way to do it? or a better way?
if i have to spend $600, it wouldnt be the worst thing, but i can definitely find better things to do with the remaining money.
Old Dec 3, 2007 | 02:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: power to manual steering
Manual steering box from a 84+ S10 is a direct fit.
Old Dec 3, 2007 | 08:41 PM
impaled's Avatar
thanks, that exactly what i needed to know.
Old Dec 4, 2007 | 09:56 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Axle/Gears: Ford 9" with 3.89
How much in weight savings is it?
Old Dec 4, 2007 | 10:35 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
pump, lines, fluid, bolts.... and a cleaner look. not a huge weight savings, but a few pounds helps!
you will need to reuse you camaro pitman arm, as the s10 will not work properly.
still an easy swap.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
