not sure what i got
Old Dec 7, 2007 | 12:00 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
not sure what i got
alright heres the deal. under the glove box thingy on the passenger side i have a badge that says performance suspension. not sure if that means it has thr ws6 package or not. its a 87 trans am with the 4bbl 5.0. when i drive it it hardly has any body roll and has a smooth transaction going into and out of corners. also i tryed to look up the vin online to see if i could find any info but couldnt find anything. so if there is a sight you guys know of that would tell me let me know thanks.
Old Dec 7, 2007 | 03:23 PM
Demon355's Avatar
Re: not sure what i got
Look in the console for the RPO sheet. Should say WS6 on that.
Old Dec 7, 2007 | 03:34 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
mine says perf. susp. as well so since i dont have rpo codes on the car just measure the front and back sway bars it should have 36mm front and 1" in the back. which i believe is the ws6 package if i recall correctly. which i am sure someone else will know for sure.
Old Dec 7, 2007 | 04:10 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
there is no rpo sheet so i'll go measure the sway bars once i get some calipers.
Old Dec 7, 2007 | 05:54 PM
Demon355's Avatar
Really don't need to have the sway bar on the car to measure it. Just use a tape measure or if you have a diameter finder then just measure the circumference of the bar.
Old Dec 7, 2007 | 06:04 PM
i just used a tape measure to find the right sizes myself.
