Cracked brackets in rear
Old Dec 19, 2007 | 09:49 AM
bfox88's Avatar
Car: 90 IROC-Z
Anyone have any pics of the rear suspension of an IROC? i have cracked these brackets on both sides of the rear susp. Dont know the name of the bracket or anything but they attach to the rear axle and are just below the control arms. Theyre almost an L shape i guess. anyone know what im talking about?
Old Dec 19, 2007 | 09:59 AM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Re: Cracked brackets in rear
Any of these help?
Old Dec 19, 2007 | 10:05 AM
bfox88's Avatar
Car: 90 IROC-Z
for whatever reason your setup looks different than what i saw yesterday when i had the car up. i'll take a look again today
Old Dec 19, 2007 | 10:27 AM
Blue1989RS's Avatar
Car: 1989 RS
Mine is a drum rear axle with disks, boxed panhard, and LCA relocator brackets. Should look close enough to pick out what cracked.
I might have another pic of the driver side with the wheel off if you need it. My general feeling is that you can weld up the crack and be fine. Is the crack on a bracket or on the axle tube?
Old Dec 20, 2007 | 12:12 PM
Shagwell's Avatar
Car: projects.......
below the control arms? - There are no factory brackets below the control arms. humm, maybe a set of those "traction action" control arms?
Old Dec 22, 2007 | 01:44 PM
bfox88's Avatar
Car: 90 IROC-Z
the cracks are on both brackets, not the actual axle tube. looks like it may be the only bracket in those pics you posted.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
