Oversized tie rods?
Old Dec 31, 2007 | 10:29 AM
Stephen's Avatar
Car: 87 GTA
Oversized tie rods?
Mine are starting to pop, so I need new ones. I looked at getting some before pulling mine apart, but they have standard & oversized ones for sale.
Is there any way to know, before I tear my car apart, what I'd need? Kinda hard to go to the parts store, when your only car is torn apart.
Old Dec 31, 2007 | 11:21 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Oversized tie rods?
whats oversized? the tapered shaft? i would assume, if that is the case, they the oversized one would be for if there was damage to the spindle that required you to ream out and enlarge the hole a bit
Old Dec 31, 2007 | 11:24 AM
Stephen's Avatar
Car: 87 GTA
That's what I don't quite understand.
Are just if you need to bore the hole out, and need larger ones? Or, are they for worn out oversized holes?
Old Dec 31, 2007 | 08:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
As I understand it, the oversized are for those that had damage and had to bore out the holes slightly - you should be fine with regular ones if you haven't had this done.
Ed1LE
Sep 30, 2018 09:14 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
