does my drag suspension shopping list look about right?
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
this car is for drag only and i will sacrifice all cornering and handeling for a good launch and sixty footer. this is what i am considering ordering, and i have researched alot, but i am still welcoming opinions.
front - lakewood 90/10's and moroso trick front springs (220 lb/in).
rear - lakewood 50/50's, spohn control arms and adjustable pan head bar (i will take recommendations as to which models).
i am going to be welding a cage in in the next few months as well as subframes. i will get some mickey thompson et streets on some 15 inch rims after i do all of this.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: does my drag suspension shopping list look about right?
Order of modifications
#1 SFC before anything else
#2 Adjustable torque arm
#3 Adjustable panhard bar and adjustable LCA both with solid heim joints (no bushings). LCA relocation brackets (if required)
#4 Lakewood 90/10 or even better, Koni SPA1 front shocks/struts
Everything after that is just a tuning aid
Front springs
Rear shocks
Rear sway/anti-roll bar
Air bags in the rear springs etc
Since it's drag only, why ET street tires? Just get ET drag tires.
Front springs
Rear shocks
i am not going to have it on slicks because i dont have a truck to trailer it to the track, and for some reason, i am not that confident that my rear end will hold up to that much abuse.
i am not getting a torque arm yet because i am not sure what transmission i am going to go with after my existing 700R4 goes.
what subframes would you recommend?
does spohn manufacture good roll cages?
morrow
Jan 13, 2024 12:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
