oem brake swap drum to disc
Old Jan 7, 2008 | 05:17 PM
yatwich's Avatar
I have an 89 Iroc that I want to put rear disc brakes on. My question is, is it possible to simply unbolt the current factory drum setup from the rear end and bolt on a factory disc setup from a 3rd gen doner rear end without any modifications? Thanks in advance for any input offered, Gregor.
Old Jan 7, 2008 | 05:42 PM
Jason89RS's Avatar
Re: oem brake swap drum to disc
Yes and no. It will bolt right in, but you will also need to change the parking brake cables, proportioning vlave and possibly master cylinder and brake line from body to rearend depending on what year the rearend came from.
Old Jan 7, 2008 | 05:58 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
It will not bolt right in as the flanges are different. It can still be done if you drill the holes on the flange for the disk setup. There is a tech article on it if you do a search.
Old Jan 7, 2008 | 06:03 PM
Jason89RS's Avatar
Oops I missread the question. I thought you were replacing the whole rearend. Then no what camarojustin said. Your best bet is to do a search on the brake board for what kind of swap you are planning on doing.
Old Jan 7, 2008 | 06:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
ebmiller offers a simple conversion. Search.
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
