could my proportioning valve be bad?
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
My brakes recently were sticking on the left side. I hit the prop. valve on the brake booster with a wrench and that solved the problem for a while. But now I believe it is back. I am having a pull to the right when i hit the brakes and when I am driving it is pulling to teh left some. I recently had an alignment and it fixed the pull to the left, but now I think it is brake related. Anyone have any stories like this?
Re: could my proportioning valve be bad?
My opinion is the rubber brake hoses are shot and not the proportioning vavle. But again, if you keep hitting it with a wench who kowns???
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
you guys mean the rubber hoses from the hard lines to the caliper?
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
If your car is pulling left the right side rubber brake hose is bad and vise versa. Reason being is that if one brake hose goes bad it restricts the flow to that brake caliper while the other side still flows good and applies more pressure to the brake pads causing it to pull. It is a common f body problem.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Okay so I will pick up 2 new hoses for it. Thanx guys for the help
backtothe80s
Sep 5, 2015 12:39 AM
