how much will my front end come up???
Old Jan 16, 2008 | 02:52 AM
86irocterror's Avatar
im planning on shaving about 150 to 175 lbs off the front end of my car. i have eibach sportlines and the front springs are 700lbs per inch. im planning on a fully aluminum engine instead of the cast iron block and heads, tubular k member and probably a fiberglass hood. and someother stuff might get removed as well. how much will my front end come up after i lighten it? thanks for the help
Old Jan 16, 2008 | 05:18 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: how much will my front end come up???
I'd say around 3/8 of an inch. Maybe more. You could get a 175 weight, put it on the front of the car (safely), measure, and then take it off. That'll give you some idea...at least I would think it would.
Old Jan 16, 2008 | 05:54 PM
That 700 lbs/in rate is the spring rate, not the suspension rate.
The suspension has roughly a 3:1 mechanical advantage on the spring; meaning, the suspension has a rate of around 225-250 lbs/in, per side, or about 500 lbs/in total for both sides. So I'd agree roughly with 91's guess; somewhere in the ¼" to 3/8" range would be likely. Not enough to be catastrophic.
That's one of the good things about high-rate springs.... lots of weight makes very little ride height difference.
Old Jan 16, 2008 | 07:31 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Nothing air ride cant fix!
Old Jan 16, 2008 | 07:36 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Or a set of Ground Control Weight Jacks...
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
