Bolt sizes etc.
Old Jan 18, 2008 | 06:11 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
Bolt sizes etc.
anyone know of a list or diagram which illistrates the grade and type of bolts used in the front suspension? I am rebuilding my front K-member now from the powder coaters and would like to use stainless steel or just new bolts. Any help is appriciated.
Thanks,
Blake
Old Jan 19, 2008 | 04:50 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: Bolt sizes etc.
most of the metric stainless products out there are too soft for use on suspension components.
id recommend going with grade 10.9 stuff.
you can get nice washer headed hex bolts from john deere, and the CAT dealers.
Old Jan 19, 2008 | 06:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Bolt sizes etc.
Allen head capscrews are typically made in the 180,000psi tensile (grade 9) strength, even stainless. I'd look at that.
Otherwise, coated 10.9 or 12.9 bolts, use high strength washers, and DEFINITELY use anti-seize.
I think most bolts that require strength are 10.9 or 12.9 in the front suspension, the exception being stuff like the little ones that hold brake lines to your k-member, etc.
Old Jan 19, 2008 | 08:06 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Bolt sizes etc.
i understand your dilemma . i am a retired acft. mech. and i too would be glad to find or buy chart for bolt size/strength . oh well , can't go wrong with overkill on bolt and nut strength . don't forget the best bolt is the worst with the wrong grade nut . oh well , anybody know of such a chart ????
evilstuie
Jan 9, 2020 08:29 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
