Can someone re-write the alignment spec table?
Old Jan 20, 2008 | 07:43 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
The one here: https://www.thirdgen.org/suggested-front-end-alignment
I can't make heads or tails of this chart. I copied and pasted it into Notepad and MS Word and neither made it readable.
Old Jan 20, 2008 | 01:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Can someone re-write the alignment spec table?
Something like this
Attached Thumbnails Can someone re-write the alignment spec table?-specs.jpg
Old Jan 20, 2008 | 02:09 PM
Car: 2012 Corvette
Engine: LS3
That's great, thanks.
Do you have any idea if any of those specs would help to correct some road wander caused by my 275s?
Old Jan 20, 2008 | 02:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
You have 275's, on the FRONT of a camaro, with a 3.1L ?? WHY?
Yea, it might find the problems that are causing the wander. Typically worn steering parts. When they go to adjust it, they'll tell you some parts are worn and need to be replaced.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
