cheap wheels for et streets
Old Jan 23, 2008 | 11:31 AM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
what are some decent cheap 15's for et streets. i like the wheels i have now, but they are only wide enough for 275's and i want a second pair. i have found cragers for about $50 a pop from jegs, but they are steel and probably extremely heavy. i am not sure about drag lights because i heard that they can bend if i were to hit a pothole or something. any recommendations? would there be a huge difference between steel and aluminum wheels as far as performance goes due to the additional weight?
Old Jan 23, 2008 | 05:02 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: cheap wheels for et streets
http://www.jegs.com/webapp/wcs/store...61789_-1_97304
these are not too expensive and look pretty good.
I've been runnin DragLites for years with no problem. The roads in 'Bamer suck too.
Old Jan 23, 2008 | 06:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
yes steel wheels will be extremely heavy.
weld pro stars or draglites are pretty cheap, the jegs or summit brand rims are cheap as well, but heavier than the welds also.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LittleFranks
Sep 17, 2015 12:22 PM
dutch930
Sep 11, 2015 06:58 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
mustangman65_79
Aug 9, 2015 03:00 AM
