Quick Spohn T/A question
Old Jan 28, 2008 | 07:17 AM
Pat Hall's Avatar
Hey guys. So many members here are using the Spohn adjustable torque arm, I figured I'd ask on the boards before bugging Steve about it. I've got a chance to pick up a very lightly used Spohn adj. t/a and crossmember from a local guy for a killer price. The only possible issue is that it has the spherical rod end instead of the poly bushing where the t/a mounts to the crossmember. My car is more a street cruiser than anything else, so I'd really prefer the poly bushing since it'd be quieter going down the road. Does anyone know if you can just swap out the rod end for the poly end using the same t/a? I'd gladly pay Steve for the poly end if it'll hook right up. TIA for any advice you can offer.
Old Jan 28, 2008 | 10:23 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Quick Spohn T/A question
How about this:
http://www.spohn.net/?action=product&pid=1666
JamesC
Old Jan 28, 2008 | 10:38 AM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
Have you tried driving it with the solid rod end. My car has had a solid one on since it was my daily driver and I never noticed any noise from it.
Old Jan 29, 2008 | 12:36 AM
86irocterror's Avatar
you dont get much noticable noise from solid mounts but you will get more vibrations and feeling of the road more. nothing crazy you just dont have that bushing absorbing that stuff any more.
Old Jan 29, 2008 | 02:07 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Pat Hall, at one time I also got a good deal on the spohn torque arm with the spherical mount, at the time it was my only suspension upgrade, and even after the install, I noticed no difference in sound or vibration, In my opinion, go with it and don't worry. If your whole suspension setup was spherical, then you would probably notice something, but one peice of equipment, no big deal at all. besides, it always has load on it while driving think about that.
Old Jan 29, 2008 | 03:13 AM
Pat Hall's Avatar
Sweet! Thanks for the advice guys. Yeah, I'm probably worrying prematurely. I'll give it a shot with the rod end first. If it does end up bugging me, JamesC gave me a link for everything I need to swap it to the poly mount. Thanks for helping a dummy like me navigate Spohn's site James! I've got a TKO 5 speed all ready to go in as soon as the weather breaks. Once I pick up this crossmember-t/a setup, I'll have everything I need to do it. Man, I can't wait to bang through the gears with the TKO this spring! P.S. When I did a search, it appears that the rod ends are mostly noisy if you have them on the LCA's.
Old Feb 1, 2008 | 08:13 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
rod end lca is only noisey is you run a cheap set.
most companies run a quality FK or aurora sp? end.
id be willing to buy the rod ended piece and its bushings should you go to a poly.
LMK.
Old Feb 3, 2008 | 06:48 AM
Pat Hall's Avatar
Sure, no problem. I'm probably gonna pick it up from the guy tonight after work. It'll be a while before it goes in the car though. We're up to our necks in snow around here at the moment. I'm shooting for April sometime to get the trans in. I want to at least run it with the rod end to see what it's like. I'll keep you posted.
Old Feb 3, 2008 | 01:11 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
thanks man. im in no hurry. i really have no reason to switch. but what the hell. ill try anything.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
