ZQ8 rims
Old Jan 30, 2008 | 06:56 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
ZQ8 rims
i got a new set last week . O.K. , put new rubber on them today . small problem , i have rear drums . they did not seat on rear axles . took my die grinder with a sanding drum , a few LIGHT circle passes on the center hole , problem solved . ( yes i did all 4 ) don't know if this is a common problem as i know many people are getting ZQ8 rims , i thought i'd throw this out . i would recommend , doing this from the backside of the rim with with a sanding drum , not a die grinder . no balance problems , took it up to 100+ , solid as a rock . i'm happy .
Old Jan 30, 2008 | 11:41 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Re: ZQ8 rims
What are zQ8 rims?
I had to modify other wheels like you mentioned and used a cylinder hone on a drill to open the center hole.
Old Jan 31, 2008 | 08:07 AM
UNCLE TOM's Avatar
Re: ZQ8 rims
ZQ8 rims come on S-10 trucks with special handling package . do a search and you will see them on a very nice vert. .
Old Jan 31, 2008 | 03:00 PM
cheyenne383's Avatar
Car: Huffy 10 speed ;)
Engine: My legs
Transmission: My wrist
Axle/Gears: Little spokey things
Re: ZQ8 rims
I used a good old fashoned hand file, but either way, the 99+ S series trucks has a smaller center bore than the older ones, so ZQ8 and Xtreme wheels both have to be bored out to work on older S10s, A/G bodies, f-bodies, and the like.
Old Jan 31, 2008 | 04:46 PM
UNCLE TOM's Avatar
Re: ZQ8 rims
thanks , thats something to tuck away in the old memory bank . i really thought it was some sort of fluke with the rear drum axles . thanks again .
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
kitt23
Exterior Parts for Sale
Nov 28, 2015 06:26 PM
dbrochard
Oct 10, 2015 01:03 PM
dbrochard
Oct 10, 2015 01:02 PM
