Rear suspension, odd sound
Old Feb 5, 2008 | 03:22 PM
Slacker85TA's Avatar
Car: '91 Firebird
Engine: LO3 305 TBI
Transmission: TH700R4
Axle/Gears: 10 bolt 2.73 gears
My T/A has an odd pop/bang sound that comes from the rear suspension whenever I pull into a driveway at low speeds. It just started happening in the last couple months. Any ideas?
Old Feb 5, 2008 | 03:53 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Rear suspension, odd sound
i had the same problem about a year ago . mine was the track bar brace also called a panhard bar . it goes from pass. side of rear axle to drivers side of body . all 3 bolts to the body had backed out and fallen away . re-installed new bolts , end of problem . this is not un-common on third gens. . if this is your problem be sure to use lock-tite on new bolts . also it is an easy fix . can't remember the size , i do remember they were metric . good luck .
Old Feb 7, 2008 | 01:48 PM
Car: '91 Firebird
Engine: LO3 305 TBI
I figured it was probably panhard bar related. I'll try that. Thanks.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
cam-mike
Aug 24, 2015 07:23 AM
