Thread size for tranny torque mount hole?
Old Feb 7, 2008 | 04:12 PM
walrus108's Avatar
Car: 1989 GTA White Hardtop
Axle/Gears: 9 bolt 3.27
What size are the threads in the ext housing on a T-5 tranny where the torque arm mounting bolt goes? I lost the top bolt while going down the road the other day. It is the one that actully threads into the housing and does not pass through. I think someone at one time tried to replace the bolt for one of the wrong threads and stripped it allowing it to slowly work it's way out. Now I need to try to repair the threads that were once there. The problem is, since I don't have the original correct bolt, I need to be sure exactly what thread and pitch was originally there before going getting a thread repair kit or something.
Anybody know?
Old Feb 7, 2008 | 09:04 PM
Re: Thread size for tranny torque mount hole?
It's 10mm, std (coarse) thread whatever that pitch is, I forget the #. The normal metric thread in any case. You can get bolts like that hanging in the aisle at AZ. Get the same size Heli-Coil as well, and that should do it.
Old Feb 8, 2008 | 10:53 AM
walrus108's Avatar
Does 10 x 1.5 sound right?
I'll have to measure the depth of the hole to figure bolt length I guess.
Old Feb 8, 2008 | 11:09 AM
Yes that sounds about right. Passes the "smell test", at least.
Should be about a 40mm length, with a washer head.
Jeremys87
Jul 14, 2022 09:08 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
