Whats the current opinion on the best strut/shock set up
Car: Camaro
Engine: 6.2L
I'm running Sportlines and wanting to swap new struts and shocks again. I have previously run Bilsteins and loved them but wonder if there are newer or better options available?
I built the car for road course use but seem to find my way to the drag strip more and more frequently these days so they need to perform okay in drag use as well. If it wasn't for the drag strip I'd get the Koni yellows and not think twice.
Thoughts?
Thoughts?
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: Whats the current opinion on the best strut/shock set up
Id go with Koni yellows anyways. Top notch struts and shocks. Since youre lowered, youre gonna love them. They are firm, yet soft. The perfect balance if you ask me!
I drag race my car once in a while (well, when it was on the road) and they performed flawlessly.
Still have the orignal Bilstien Struts & Shocks and still as good as ever. Original owner of 1987 IROC-Z, so I would recomend Bilstiens
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I dont have any first hand expieriance with KONI Yellows, but I plan on getting them for my car in a month or so (when the snow is gone). But then again, I will be autocrossing my camaro.
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
You may want to replace those. I recently installed a set of new Bilstiens on my 1987 IROC. The original stock struts were shot! I removed them compressed them and they did not rebound.
These still rebound and I have been the only driver of this car so I known they are still good for a lot of miles.
Engine: 305 LB9 TPI
I didn't know that mine were toast until I removed them from the car. The coil springs were the only thing rebounding, the struts were just going along for the ride. They weren't damping much...
The new Bilstiens are awesome! They have a lot of resistance and rebound when compressed by hand. They seem well built and have a much better ride!
Car: Camaro
Engine: 6.2L
I can second Bilsteins durability. My original Bilsteins were fine until I slammed the car and ruined them. I didnt know then that lowering would kill them. They worked great on the stock springs and lasted for ages and ages. I had a Porsche once that had them too and again great shocks. I hear great things about Koni's and all and the adjustable aspect sounds nice but I have haad adjustables before on a sled though ( snowmobile ) At first I played with them all the time but after the first season once I had them set where I liked it I left them there. This has me thinking because I really liked my last set of Bilsteins so maybe I should just not mess with success and stick with them. I certainly dont think that is a poor choice at all. I'd still like to hear more. Thanks guys
Car: 1992 GTA
Axle/Gears: 4.10
I just sold my NIB Carerra QA1 rears and Koni Yellow front struts. I am lowering the car and wanted something that is designed with the goemetry in mind, plus I wanted to be able to adjust for track or street, ect. I am going with the Tokico Illumina adjustable shocks/struts and lowering springs on the advice from a few people that I respect.
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i dont know much about the konis (if they are adjustable or not), but i would get some adjustables. i have kyb agx's on my stang and they are really nice for the price ($300), however i KNOW that there are better adjustables out there.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Bilsteins. Had my 85 since new and Bilsteins that you buy today are much better than OEM bilsteins. OEM rears are not Bilsteins so I upgraded rear to Bilsteins. Again, much better results.
Car: Camaro
Engine: 6.2L
Yeah the Bilstein HD's ( sports in my case ) I have heard are valved a bit tighter than the stock Bilsteins.
Anyone know if there are any shocks available that are remote adjustable?
Car: Camaro
Engine: 6.2L
Alright so I've done a fair bit of research and from what I've read it seems the Bilsteins no longer come valved as aggressively as they used too so a revalve is nec. This has me leaning towards the Koni's now and I especially like the adjuster **** on top of the strut tower.
I'm wondering is anyone knows whos got the best prices on the Koni's?
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
Hotpart.
http://www.hotpart.com/index.php?&ke...d=63&catcount=
He also makes one of the best upper strut mounts. $200 for the pair, and new stock-style ones are $90 each. Might as well go aftermarket for $20.
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
KONIs are what I have and I like them. They are adjustable as well.
And you might as well get the shock mounts like HotParts or Spohn while you are at it.
Car: Camaro
Engine: 6.2L
Ya I will be getting the mounts too. Shame I bought new stock ones last season in a rush to get it out ( I lost my stockers during the LS1 swap somewhere )
Do those hotparts ones raise the height of the strut like the Spohn ones do or do they keep the strut at the same height as stock?
http://www.spohn.net/?action=product&pid=1148
anyone?
anyone?
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Car: Camaro
Engine: 6.2L
Cool thanks! Anyone know about the strut mount height on those hotpart units?
Car: 1991 RS Camaro
I'm not sure, but mine (being the old design) don't have any clearance issues with the Pro-Kit I'm running. Plenty of travel, and I've never hit the strut on the mount. The new ones should offer at least as much height as the stock pieces, if not more. I'd send HotPart an e-mail and see what they say, though. At least you would be getting the info from the source.
Car: Camaro
Engine: 6.2L
Wow blazing fast replies over there at Hotpart. Heres what they said
Only thing i wonder about is I killed my stock shocks/struts by lowering the car. They didnt bottom out or anything but I read somewhere that it messes up the shock when you lower it because it cycles the shock where it wasnt designed to run. Seeing as Koni's are 250 a pop I'd like to figure this out before laying out the coin. I'm running Sportlines so I am waaaaay low
Thoughts?
We have found that the strut does not need to be raised when using moderate lowering springs. The limit of bump travel is caused from the bumpstop that is mounted on the control arm. We designed these on a car that we trimmed the bumpstop in half and the strut still didn't make contact with our camber plates. We do recommend anytime you trim your bumpstop to run the suspension completely through its travel to make sure there are not any clearance issues though because every strut manufacture is different.
Thoughts?
Car: 82z28
Engine: 406
Transmission: th350
Quite a few folks running the hotpart mounts at lower heights, under harder conditions, and with higher spring rates...that being said, do what they recomend...cycle the suspension and make sure your bumpstops prevent you from bottoming the suspension.
Car: Camaro
Engine: 6.2L
I'm not at all concerned about bottoming out the suspension I can make sure that wont happen. I just dont want to prematurely cook my struts from running them in a less desirable neutral position and cycling them in a stroke pattern that they are not designed for
Car: Camaro
Engine: 6.2L
I guess what I'm asking is do Koni Yellows really need the raised strut mounts? Will it damage them at all ( providing I avoid mechanical collisions ie; bottoming them out ) if I run them in such a low position?
Car: 1991 RS Camaro
I've been wondering the same thing about them for a while now. I've had them on my car for about two years or so...I think. I've not noticed any change in performance, but that doesn't mean it hasn't occured. Might be worth looking into. I wonder if KONIs tech support is as good as HotParts?
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
I had 1 7/8 spacers made to run under the stock strut hat. So there is no loss in travel for the front damper despite the vehicle being lowered. I'm running with Tokiko Illuminas (love them) and I figured this measure would save killing them over time. The only thing is that the stock threaded studs that come up from underneath the "strut tower" are not long enough. As it happened, I had a set of the Hot Part camber plates and used their stud bracket.
I decided against the HotPart CC plates because using the provided spacers (beefy washers) you now have a big gap between the plate and the chassis of the car. The engine would have always been coated in road grime etc. Also, they alow for so much positive camber that I would have had to hack of a piece to align the wheels and still close the hood. It's not that they are a poor part but, to my mind, really more for the track than the street.
If you can afford the down time, I say, remove the strut hats (mounts-whatever you want to call them) and for the same price a machine shop can CNC you a spacer that will look better and allow greater strut travel.
Car: Camaro
Engine: 6.2L
Good points Jonathan. I heard back from Hotpart again heres what they said
Have you trimmed your bump stops? The car we designed them form has Koni's and sportlines. If you have not trimmed your bump stops you will NOT hurt the struts. If you have trimmed your bump stops no matter what you use you will need to run the suspension through its travel to make sure they do not bottom internally.
Car: Camaro
Engine: 6.2L
Looks like its all good. Heres a quote I received in response to my email to Koni straight fromthe horses mouth;
Thanks for the help guys
You will not need to worry about moving the upper mount with those springs. Thanks.
ambainb
Apr 25, 2016 09:21 PM
Thornburg
Aug 25, 2015 01:46 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
