which improves stability?
Old Feb 10, 2008 | 01:49 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
hey guys, a 91 RS v6 automatic here.
I have 190k miles so far but I replaced all shocks/struts
motor mounts tranny mounts,ball joints, both swaybars+links, panhard rod,
steering braces and UMI SFC.
car is nice and stiff, but I feel like over a little bump I feel like sometime it jounces a little too much.
my spring or coil or whatever my car comes with are still original,
and I remember seeing like this unknown fluids leaking near my tire before,
does this mean my shock had a leak and it needs a new one?(was a monroe shock btw)
so to make car stable and more stiffer, should i go new spring first or new A-arm or new shock? or new tie rod helps?
i feel like I spent so much on suspension and the ride could be much better.. maybe its just me but Im broke so I cant do all at once plz advice me on which 1 i should take priority on, thanks!
Old Feb 10, 2008 | 05:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: which improves stability?
I'd check the shocks first. If you discover nothing, you might consider springs. The A-arms and tie rods won't eliminate "jounce."
JamesC
F-body-fan
Jan 12, 2023 01:49 PM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
1992Z28!
Nov 19, 2015 07:33 AM
wanext
Oct 6, 2015 12:18 AM
roysatikas
Sep 22, 2015 08:15 PM
