Better springs for wheelhop?
Old Feb 17, 2008 | 01:13 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I've got new rear springs in my car now, it was the 4 piece kit that Spohn used to sell. I was under the impression they were factory replacement for IROCs. It seemed to start wheelhopping at that point and I want to try some different springs. Whats a good spring to try?
Old Feb 19, 2008 | 06:12 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
Re: Better springs for wheelhop?
You shock are probably not valved correctly or worn out and can not control the new, stiffer spring rate. That is, of course, assuming that you have an otherwise tight rear suspension and decent torque arm.
Old Feb 19, 2008 | 02:18 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
The only thing stock about the rear end is torque arm. All bushings are new poly in aftermarket arms. Shocks are new Konis.
Old Feb 19, 2008 | 05:59 PM
Engine: 355 / 355
The I would suggest adjusting the shocks 2 or so clicks tighter and go from there.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
