What The Right Way To Install SFC'S ??
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Should the car be lifted on a 4 point lift or an alignment rack lift? Does the suspension need to be loaded with the cars weight?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What The Right Way To Install SFC'S ??
suspension needs to be loaded
Car: 86 Trans Am
its possible, that with the car jacked up and the suspension hanging, that the car could flex a little. When you weld the connectors in the flex will be permanent. It may not be a huge difference, or even noticeable, but i could cause alignment issues i suppose.
gixxer92
Sep 1, 2015 04:32 PM
