rack and pinion length?
Old Feb 18, 2008 | 08:15 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
im going to be modifying my steering arm and going with a manual rack for drag racing.
all the "kits" from aje, pa, etc.... all have shortened tie rod ends to work with our cars. is this needed with a shortened steering arm, or can i use a std length pinto rack, unmodified?
Old Feb 20, 2008 | 12:21 PM
Shagwell's Avatar
Car: projects.......
Re: rack and pinion length?
IMO - the mustang II style racks are much easier to mount. They have two cast ears with bushings, thus only require two studs/bolts to be mounted. - The shortend steering arm won't change the rack/tie rod length, just the axle center to tie rod center length.
Not sure about the pinto, but the mustang II style rack doesn't need any shortening when used with a bump-steer kit(thread sleeves and rod end outer tie rods).
Ed1LE
Sep 30, 2018 09:14 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
dimented24x7
Sep 17, 2015 06:58 AM
