how to remove rear shocks
Old Feb 29, 2008 | 09:02 PM
bb87camaro's Avatar
How do you get the rear shocks off of an 87 Camaro? The person I got this car from put new carpet in and I think he covered them.Where approx. are they in the car?
Old Feb 29, 2008 | 09:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: how to remove rear shocks
right behind the rear seats under the carpet almost to the top of the "hump" behind the seats, before the cargo area, you will have to remove the panels and pull back the carpet to get to the mounts
Old Feb 29, 2008 | 09:59 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
Engine: 305 V8 carb'd
Here is a picture of the inside bolts. You need to remove these first then remove the bottom ones under the car. The one on the driver side was rusted so bad I had to cut it off.
Old Feb 29, 2008 | 10:26 PM
bb87camaro's Avatar
Thank you for taking the time to answer my question and for the excellent picture.This will save me from tearing more of the car apart than I have to.
Old Feb 29, 2008 | 11:19 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
You DONT have to take out the panels. All you have to do is flip the seat down and pull back the hatch carpet.
Kevin
Old Feb 29, 2008 | 11:28 PM
86-Iroc-Z's Avatar
Car: 86 IROC-Z
When I did mine last week the car didn't look like my picture, that pic was before I put it all back together. I had brand new carpet in mine & it was too far up under the panels to just pull it back. I had to remove some of the panels to get the carpet back to get to the bolts. But maybe the stock carpet is easier to pull back??
Old Mar 1, 2008 | 02:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i just found that the carpet is tucked under the panels. You can pull it out easily enough, but putting it back under is a bit difficult.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
