traction bars?
Old Mar 7, 2008 | 11:06 PM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
traction bars?
well i should be getting my credit card in the mail hopfully monday. beenign waiting almost 3 weeks and its bound to show up anyday now.
anyways i was just checking out the jegs website to see what i can buy with my new shiny credit card. and i stumbled across this.
http://www.jegs.com/i/Lakewood/620/2...744077%7C10083
would this work? and how does it work? anyone know?
is it worthless or would it be a good upgrade to the suspension for launching?
and
Old Mar 8, 2008 | 01:30 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: traction bars?
did you even bother to see that they're not made for thirdgens?
get some quality UMI parts or similar and run them. LCAs, panhard bar, torque arm, relocation brackets, etc etc
Old Mar 8, 2008 | 09:39 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: traction bars?
Those are for A/G body cars.
Third gen suspension doesn't get axle wrap the same way other suspensions get. "Traction bars" don't work with third gen suspension.
All you need is a few basic aftermarket suspension components to replace the weak factory stuff.
Adjustable torque arm that moves the front mount off the transmission. The adjustability allows you to adjust the pinion angle.
Lower control arms and relocation brackets. Poly bushing ends are fine for a street car. Rod ends for a race only car.
Old Mar 8, 2008 | 09:40 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: traction bars?
if you posted the wrong link by accident and meant to post the lakewood traction/lift bar setup that they make for the 3rd gen, dont bother with them either, they are not the best things out there. Stick with a good set of LCA's, panhard, crossmember mounted torque arm and such from UMI, spohn, ect... whoever you prefer
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
