Wheel Offset question.
Old Mar 8, 2008 | 11:19 AM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Alright, I am having some issues on what route i wanna go, I have some c5 wagon wheels, but dont really want to go staggered sizes, and tirerack.com and discounttiredirect.com dont show alot of wheels for our cars, but if you do a search on tirerack.com for say a 17in wheel with the correct bolt pattern it brings up alot of wheels just with different offsets. Now my question is, the ones I want are a 17x9 with a 0 offset, that means the bolting flange is right in the middle, so 4.5 inch backspacing right? Ya. so am I gonna have to use a spacer with these wheels? or will that be the right backspacing? Please help.
Old Mar 8, 2008 | 11:28 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Wheel Offset question.
a 9" wheel will measure about 10" wide. so the bs will be about 5", should still fit, though i think the tire will be flush with the fender
Old Mar 8, 2008 | 11:31 AM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Well, I can do a fender roll, or trim the lip if i need to, as long as I dont need spacers, and that the wheel will clear on the inner side. and still be able to turn.
Also...How wide of a tire will fit on a 9" wheel? and still fit under the car, I was gonna go 275/40's
Old Mar 8, 2008 | 11:47 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
275/40/17 should work fine, factory diameter
ChristinaMarie
Sep 11, 2015 06:28 PM
scottmoyer
Sep 7, 2015 07:06 PM
TheExaminer
Sep 6, 2015 11:40 PM
84 TA NV
Sep 6, 2015 08:02 PM
Ian Irvine
Sep 4, 2015 08:08 AM
