front spring indexing?
Subscribe
Mar 13, 2008 | 03:14 AM
Does anyone have a picture of how eibach sportlines need to be index in the front LCA? the old ebmiller88 posts dont link to current photo's available. I just installed sportlines, but they dont seem low enough and just want to make I installed the fronts correctly.
thanks!
Reply 0
Mar 13, 2008 | 03:20 AM
Re: front spring indexing?
as long as you rotated the ends into the "pocket", you should be fine..
when i had my sportline drop
Reply 0
Mar 13, 2008 | 06:11 AM
I have no experience with lowering springs, so I may be completely off base. OE springs require that the coil's lower end be positioned between the two drain holes on the a-arm (IIRC, one hole can be covered but not both).
JamesC
Reply 0
Mar 13, 2008 | 10:29 AM
rotated into the pocket? there was no pocket for me to rotate into. or at least that I could tell.
Reply 0
Subscribe
