Transmision movement
Old Mar 13, 2008 | 10:09 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
My shifter raises about an inch in my hand as i accelerate. I know it is caused by the torque arm. Would replacing the transmision mount with a polyurethane one help this? LCA lowering brackets? A custom crossmember with torque arm relocation is in the future as are the LCA relocation but for now will the mount improve anything or is it a waste of $?
Old Mar 14, 2008 | 06:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Transmision movement
More than likely the problem is your OE mount (which at this point is probably shot to heck, especially if you have a secondary trans mount). Climb under the car and take a peek.
https://www.thirdgen.org/forums/atta...ber-mounts.jpg
JamesC
Old Mar 15, 2008 | 02:39 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
yeah mine snapped entirely and it was my mount, make sure it hasnt broken and when you replace it spring for that polyurethane, it'll last longer, check your motor mounts too because if they're old and your tranny is moving, your engine may be as well causing them to rub apart
Old Mar 15, 2008 | 12:04 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Thanks guys, i will be putting the polyurethane one on today.
Old Mar 15, 2008 | 07:22 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Yep that fixed her right up.
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
BWilcox
Sep 20, 2015 12:19 PM
mizz0313
Aug 12, 2015 06:45 AM
86_Dan_Z28
Aug 14, 2001 11:02 PM
NickS
Feb 22, 2001 08:59 PM
