play in tilt steering
Old Mar 29, 2008 | 12:25 PM
dealerkiel's Avatar
Car: 1992 firebird
Engine: stock 305
Transmission: stock
Axle/Gears: stock
i have play/movement in my steering column at the tilt joint. movement is not as bad in the full up or full down position but in the middle setting, where i have it set while driving, there is a lot of play. i don't think just removing the steering wheel is going to do me any good because the play/movement seems futher down the column right at the tilt lever. is there a bushing to replace or a nut to tighten or is a complete steering column replacement the only way to get rid of the play, i used the search function with no luck but i would
think this is a pretty common problem, thanks
Old Mar 29, 2008 | 06:31 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: play in tilt steering
https://www.thirdgen.org/steeringcolumn
Old Mar 30, 2008 | 07:40 AM
dealerkiel's Avatar
Car: 1992 firebird
Engine: stock 305
Transmission: stock
Axle/Gears: stock
thank you very much. i will be doing this today
Old Mar 30, 2008 | 09:28 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
https://www.thirdgen.org/forums/tech...ck#post3451256
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
Night rider327
Sep 25, 2015 04:19 AM
