NEED HELP
Old Apr 6, 2008 | 03:02 PM
ONEFASTZ's Avatar
Car: 1986 CAMARO
Engine: 434
Transmission: th400 rmvb,nc 4500 stall
Axle/Gears: MOSER 12BOLT,35splineaxels,4.33gear
NEED HELP
im trying to figure out how to set my suspension up....
any ideas can help
this is what i have
pa-torque arm adjustable
pa- lcas adjustable
pa-panhard bar adjustable
moser 12 bolt with lca relocators
wolf under rear anti roll bar
tubular k member and a arms
right now the car is picing up the wheels about a foot which i like but
Ive got a pretty big ci motor and shity 60' s on a 225 shot its doing 1.45s
and i think it should be better.... plus it spins alittle...
thanks Derek(onefastz)
Old Apr 7, 2008 | 06:59 AM
monsooni's Avatar
Car: 83 camaro
Engine: 355 sbc 525hp
Transmission: 350 turbo built
Axle/Gears: 4.56
Re: NEED HELP
What is wrong with 1.45 60' pretty good to me. Sounds like you have the right suspension parts and one hell of a motor. What is the hp on the motor have you run it in the quarter. Are you leaving the line on foot brake or trans brake.
Oh yea what tires and size are you running in the rear?
never mind about the tire and quarter times i see it in your post
Old Apr 7, 2008 | 09:41 PM
ONEFASTZ's Avatar
Car: 1986 CAMARO
Engine: 434
Re: NEED HELP
the motor made 445 to the wheels and on a 225 shot it made 625 to the wheels....oh and im leaving on foot break.....
Old Apr 7, 2008 | 09:52 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
Re: NEED HELP
any twisting probs?
Old Apr 7, 2008 | 11:25 PM
ONEFASTZ's Avatar
Car: 1986 CAMARO
Engine: 434
Re: NEED HELP
no leaves pretty even maybe a inch higher on the driver side!
