Poly mounts
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Axle/Gears: 3.42 Posi
Poly mounts
I recently started a rear end swap and all the old mounts are brittle or broken. where is a good place to get new poly mounts and can you get all of them with grease zerts.? Thanks
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Poly mounts
http://www.spohn.net/
JamesC
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: Poly mounts
If you still have the stock LCA and PHB then you should just buy UMI's rear package. They have tube pieces that come poly/poly, poly/rod, or rod/rod depending on the ride you want and the budget you have. Based on their pictures it looks like the poly ends have the zert fittings.
camaro1185
Oct 26, 2015 06:51 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
