Rear end question
Old Apr 9, 2008 | 04:16 PM
FixxxerZ28's Avatar
Rear end question
Hey all.
I have a question regarding a rear end for my camaro, so I thought this would be the best place to ask.
I have a 1984 camaro z28, and I want to know if a 10 bolt 2.73 posi would fit in my car.
Thoughts?
Old Apr 9, 2008 | 06:30 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
Re: Rear end question
first off you have to make sure your rearend is a 10 bolt.duhh and second you have to make sure the axle splines are the same youll either have 26 or 28 spline axles, im not sure if it matters what series the carrier is (series two or three) i know if you install a series two carrier and you want to put a higher ratio like a 3.73 gear you have to get spacers to go behind the ring gear im just not sure if you can just install any series carrier in any rearend hope that helps you out a little
Old Apr 9, 2008 | 07:41 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
From what I heard, the series two carrier is only good for gears up to 3.08 and the series three is good for 3.23 and up.
Old Apr 9, 2008 | 08:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Your car will have a 7.5" 10 bolt. A 7.5/7.625" posi will fit. There are also 8.2 and 8.5" 10 bolts and nothing is interchangeable between the 3 different 10 bolts.
If we knew exactly what engine you have and what transmission, we can tell you what gears were in your diff when it came from the factory.
Why would you want a posi with a 2.73 highway gear? A gov lock would do just as well and without a performance gear, you wouldn't hurt it.
Old Apr 10, 2008 | 09:56 AM
FixxxerZ28's Avatar
First, I think I should say that I pretty much know jack about cars.
Gear ratios and all those other numbers are beyond me at this moment. Trying to learn as I go. Ya dig?
Second, my camaro has an automatic trans. I'm building a bored 350 for it.
Old Apr 11, 2008 | 05:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you're talking about swapping the entire rear end into your car, yes, it's a bolt-in. You'll probably have to throw in a drive or driven gear to make the speedo read correctly. Then there's the master and prop valve to consider depending on whether the rear is drum or disc. A search will provide more info.
JamesC
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
