hear a knock when i drive...
Old Apr 12, 2008 | 07:23 PM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
my car started knocking last night and i know its coming from the drivers side front wheel well.i think its the ball bearings. i also had the car jacked up last night on the passenger side.could all the weight caused something to get loose and make it rub agsinst the wheel
Old Apr 13, 2008 | 09:13 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: hear a knock when i drive...
I wouldn't expect the wheel bearings to make that type of noise, however it is likely that a balljoint, outter tie rod end or strut mount is. My GTA had a popping noise in the front that was dry balljoints...previous owner never greased the front end. I've since replaced modt of the front end parts.
Old Apr 13, 2008 | 09:20 PM
hoogabooga's Avatar
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
Is it popping just when you go over a dip or bump?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
efiguy
Sep 27, 2015 01:30 PM
