Tire size for 92 formula
Old Apr 11, 2008 | 03:17 PM
kevin92's Avatar
I am restoring a 92Formula.Currently they have 215/55/15.I plan on using the original rims but I want to go bigger/fatter.Can someone recommend a good agressive tire size that wont rub?
Old Apr 11, 2008 | 03:45 PM
bumble bee's Avatar
Car: 87 iroc
Engine: LB9 5.0L
Transmission: t-5
Axle/Gears: 373
Re: Tire size for 92 formula
try 245/50/15
Old Apr 11, 2008 | 03:47 PM
kevin92's Avatar
These wont rub?
Old Apr 11, 2008 | 10:48 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Am I missing something here...I'm pretty sure all formulas got 16x8 wheels, with a factory tire size of 245/50/16.
Old Apr 11, 2008 | 10:57 PM
Stephen's Avatar
Car: 87 GTA
Nope. There is a crosslace wheel that is only 15x7, so a 245 would be a bit big. Try a 225-235.
Old Apr 11, 2008 | 11:33 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Correct. If it has the 15x7 crosslaces, it's the wrong wheel or it's not a Formy. Check for RPO codes W66 and WS6.
Old Apr 12, 2008 | 06:14 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
guys.....tsk, tsk
No Formulas ever had 15" rims. All Formulas are WS6--with 16X8 wheels (3 styles of wheels for Formulas throughout 87-92)
watajob--chuck those 15" rims and get the proper 16" rims your car was built with and your suspension desperately needs.
Old Apr 12, 2008 | 06:46 PM
Stephen's Avatar
Car: 87 GTA
I was referring to A stock 15 x 7, not that IT was stock on Formulas.
True...Formulas, FROM THE FACTORY, got 16x8. I only meant to refer to an OEM 15x7, not necessarily stock FOR A FORMULA.
Old Apr 13, 2008 | 11:01 PM
watajob's Avatar
Car: 92 T/A 'vert
Originally Posted by 871LEIroc
guys.....tsk, tsk
Uh, that's what I said. Please Windex your glass eye.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
