Spohn wonder bar fitment
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
Has anyone had problems with installing a Spohn wonder bar or any other type? I tried to install mine and the dual fans get in the way and seems no way around it. I even ground down the lower fan mounts for clearance but still not enough clearance. Is there any other way or am I just out of luck? The rest of my suspension is done up nice and now I have a brand new wonder bar with no fittment. Any help?
Re: Spohn wonder bar fitment
There wonder bar is moved slightly forward and causes it to hit the fan shroud on vehicles with dual fans. Ours did the same thing until we revised it. You have to trim the shroud in order for it to work.
You may also consider ours, it will clear. The picture shows the older version, our newer version looks a little nicer.
www.umiperformance.com/2030
Hope that helps!
Ryan
Hope that helps!
Ryan
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm using the Global West version. There is no fitment problems with my dual fans.
JamesC
JamesC
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
I have the spohn one. I had to file down the lower fan mounts to clear.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
mine fit fine around the fans.
i did have to hone the holes out a lil bit, and start all 4 bolts loose and pull each side up a lil at a time. not sure if this is the case with all, or just mine.
car had been in a previous collision before it found me.
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
Mine fit well, maybe something has (settled). I didn't have problem one
darwinprice
17
Oct 11, 2015 11:51 PM
