295 tires on 16x9.5
Old Apr 15, 2008 | 08:44 AM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
295 tires on 16x9.5
I plan on widening my 16x8 inch stock rims to 16x9.5 on the back rims only and put 295/50/16 tire on them from bfgoodrich http://www.bfgoodrichtires.com/bfg/vehicleInfoSubmit.do here they are. So with this i think if i put 1.5 inch spacer on each side in the rear which is the width i am widening them so would this fit and not rub. correct me if i am wrong
Old Apr 15, 2008 | 09:25 AM
Stephen's Avatar
Car: 87 GTA
Re: 295 tires on 16x9.5
You can run the BFG 295/50R16s on the stock 8" wheels, no spacers.
Old Apr 15, 2008 | 04:05 PM
Norm Peterson's Avatar
Car: '08 Mustang GT
Engine: 4.6L
Transmission: º º 0 . . . |-|-|
Axle/Gears: 8.8", 3.55
I realize that BFG claims you can run that size on 8's. But having 2" of sidewall bulge per side would make me very nervous. Particularly in a performance car.
Norm
Old Apr 15, 2008 | 04:29 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
I dont know if i would go a whole 1.5" spacer. Theres a fair bit of room on the inside of the fender for the rubber to tuck in. Since the mounting position will be the same, i would suggest mounting the wheel and seeing how close it is to the outside of the fender, and see if your happy with it. I think the wheel would stick out if you went with a 1.5".
Get them widened, and decide on a spacer later.
Just to give you an idea, my 17x9.5s in the rear have a 275 on them, they used to have a 285 on them, and id imagine a 295 would be almost identical. They have an almost 3" lip on the outside of the wheel, so id imagine a good 6" of backspacing. And they JUST fit. About a pinky finger's width away from hitting anything.
Old Apr 15, 2008 | 05:21 PM
Stephen's Avatar
Car: 87 GTA
Norm
It's the sidewall height that allows it to fit. A 295/30 would NOT fit a 8" rim. Look at what 4x4s do, in regards to tire width compared to rim width.
It's the H rated treads & pattern that bugs me.
Old Apr 16, 2008 | 08:40 AM
Car: Camaro RS
So do you think it would look better on a 17x9.5 rim than a 8 inch rim?
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
