Tire width question
Old Apr 30, 2008 | 03:58 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Transmission: reverse valve
Tire width question
Forgive me if this was asked already, I didn't serach to hard for an answer, just a quick browsing.
Anyhow, I am going to put some wide tires on the back of my 1985 Trans Am. I was wondering what is the widest you can go on a 15 inch rim without modifying anything? I am sure someone here has or had experience doing this.
Someone where I work said I should try 295 50 15. I figured I'd better ask 1st before trying it.
Old May 1, 2008 | 09:00 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
Re: Tire width question
ah come on guys... you can't tell me that no one has ever figured this out. Someones gotta know!
Old May 3, 2008 | 07:42 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
295 50 15 will fit on a 8-10" rim. However, the 295 is .6" taller than the stock tire which will cause your speedo to be a bit out.
A 275 50 15 is almost as wide and has the correct height (25.9").
Old May 3, 2008 | 10:25 PM
thebufenator's Avatar
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
aren't the 15" rims 15x7?
Old May 3, 2008 | 11:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Factory rims are 7" wide.
A 275/50 will have about 10.5" of tread. A 7.5-9.5" rim should be used.
Old May 23, 2008 | 07:56 PM
aletheian's Avatar
Car: 1985 Trans Am
Engine: v8 305
My rims are 15 x 7 factory. I am going to get 275 or 295 so I think I will go with a 15 x 8 or 15 x 9 rim for the rear. I am keeping my 245's on the front.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
