passenger door binding, twisted frame?
Old May 1, 2008 | 10:25 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
i thought id ask here before i installed my SFC's next week. The car had both its doors open and close like a charm. No accidents, or anything. They both opened effortlessly, and closed without any drama.
However the car was up on stands over the winter for my T56 install. The front wheels were on the car, and they were sitting on ramps. The rear wheels were off the ground, and the car was supported on the rear subframe, JUST before (forward) of the control arm.
The car was lowered yesterday, and after washing i went to open the passenger door, it felt like it was locked. I made sure it wasnt, and i pulled harder, and sure enough it opened. Its binding somewhere, but there no paint scracthes on the door, or the door jamb. Its ONLY happening to the passenger door.
Has the frame twisted? Can i tell which way? If so, how? I have no idea WHERE its binding, but i know it is.
Old May 1, 2008 | 01:48 PM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Re: passenger door binding, twisted frame?
You could try to lift the car up on one side slowly and see when the door opens normal. Maybe you could even bend it back doing it like that!
Old May 1, 2008 | 06:59 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i really doubt you twisted anything, when you jack up the car and lower it onto the jackstands on the frame by the control arms, watch and see how much the metal moves when you lower it. It moves quite a bit.
Take the car for a spin, if you can, let the suspension settle and then check again. I think you are fine
Old May 1, 2008 | 08:06 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Old May 2, 2008 | 09:04 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Insurance goes on today, so i think i might do that.
I have noticed that the metal moves QUITE a bit. I was able to flex the floors underneath when bracing to tighten a bolt. But hopefully all is well. I was just concerned because im installing SFC's real soon.
Will keep you guys updated.
Old May 2, 2008 | 10:37 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Thanks for all the help. As you suspected, it just needed some time to settle in. 2 days later, the door opens just fine.
Hotrodboba400
Dec 10, 2019 07:07 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
