sway bars sizes for GTA's or I-rocZ28's
Old May 6, 2008 | 09:52 PM
FireTurdWS626's Avatar
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
hi, i'm trying to find out the stock sizes on these modles..... i recently measured the ones on my 88 formula......disappointment :-( 28 up front and 17mm in rear. Mainly my purpose is to just go to a junk yard and find one of these modles to get the sway bars off it.
Old May 6, 2008 | 11:08 PM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Re: sway bars sizes for GTA's or I-rocZ28's
36mm front, 23mm rear. Your car should have come with those. Check your SPID label for a W66 code(Formula), also WS6 and FE2(big sway bars ect.). 34mm front bars are easier to find and would still be a huge improvement or what you have now.
Old May 7, 2008 | 12:08 AM
Engine: LO3 305 tbi
maybe i measured it wrong i use a dial caliper. is there a specific spot on the sway bar i should measure? or do you recomend another way to measure it
Old May 7, 2008 | 12:20 AM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Just measure anywhere on one of the straight areas. If you're converting from inches 36mm=1.417", 23mm=.906"
Old May 7, 2008 | 05:26 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link may provide some helpful info:
https://www.thirdgen.org/forums/faq-...-sway-bar.html
JamesC
Old May 7, 2008 | 07:55 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
my iroc came with 36/24s
Old May 7, 2008 | 08:46 PM
JamesC's Avatar
Must have been swapped in. Like my 85 IROC, you probably originally had the 34mm/24mm combo. The hollow 36/solid 24 can be found on some Camaros from 89-92 and some thirdgen Pontiacs from 86-92.
JamesC
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
