Tokico vs. AGX's
Old May 10, 2008 | 01:41 AM
DF'sCamaro's Avatar
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
Tokico vs. AGX's
I looking at getting a reasonable price adjustable gas shock/strut and springs for my '92 Camaro. Which is better for street and strip Tokico Illumina and springs or KYB agx's and eibach springs. Or is there something better without going to coil overs?
Old May 10, 2008 | 05:36 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: Tokico vs. AGX's
If you use the agx's, you should not use the ebach springs. the AGX's are supposed to be used for stock ride highth only, they will wear out exponentially faster with a lowered car. The Tokico's are are a proven design, Though IMO a little hard to find. The illuminas are golden. The best thing about coilovers is the adjustablilty, Though I have heard tge ride is very harsh.
Cheers!!!
Old May 10, 2008 | 09:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yup, koni yellows $$$,
i have coil-overs, i dont think they are particularly harsh
Old May 11, 2008 | 01:27 AM
DF'sCamaro's Avatar
Car: 1992 RS Black
Axle/Gears: 4.10
Coilovers
After looking at Spohn's price for front coil-overs and seeing that my struts are blown up front. I am leaning toward Spohn's front coil-over kit. Any one recommend these or anything else? Also does coil-overs up front and shocks in the rear work well together.
Old May 11, 2008 | 09:21 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
spohsn front coil over kit still requires you to use front shocks. this kit installs over the strut, so you should still buy a good fornt strut
honestly, they are a bit overkill for a street car. a good set of shocks will do just fine.
Old May 12, 2008 | 03:45 AM
DF'sCamaro's Avatar
Car: 1992 RS Black
Axle/Gears: 4.10
Thanks //<86TA>\\ :I order set of Tokico Illumina shocks/struts and lower springs off ebay 540 shipped. I do have most of Spohn's suspension part, k-member,a-arms,ect but will look into getting there coil over kit later.
Old May 12, 2008 | 04:08 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
WOW Learn something new every day that set up looks great.
customblackbird
Aug 15, 2021 10:16 PM
3.8TransAM
Sep 17, 2015 02:16 PM
Jack
Aftermarket Product Review
Nov 25, 2001 07:55 PM
CleanRS
Apr 1, 2001 08:07 AM
86Trans Am
Jan 12, 2001 10:55 AM
