Front end question.
Front end question.
Since everyone seems to use the rearend from a fourth gen what about the front end. Is that a direct bolt in, lots of fabrication, or can't be done. My experience is with the 2nd gen. Just starting this project and have several ideas.
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: Front end question.
I asked the same question on here before. I was told it can't be done, but I was raised with the belief that anything can be done if you have torches and a welder. Once i get out of Iraq I am going to try that myself. The front suspension leaves a little to be desired on third gens. I am hoping to compare measurements before I even get home, but I don't have access to the cars to compare yet. It may not be worth it, I don't know yet.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can use the 4th gen front setup, it requires you to cut the entire front of the car off and swap it, its totally different. there is a couple pics floating around of a camaro with the 4th gen front grafted in, probably much more work than its worth
Terrell351
Jun 13, 2021 01:13 PM
