Koni reds vs Yellows?
Old May 29, 2008 | 03:32 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
What is the big difference between these two struts and both are adjustable correct?
Old May 29, 2008 | 07:58 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: Koni reds vs Yellows?
Reds arent if Im not mistaken. Only the yellows are adjustable, hence the price difference.
Old May 29, 2008 | 10:42 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Spike-Z is correct. The reds are not adjustable and the yellows are. The reds are a little stiffer than stock (when the stock unit was brand new) but the yellows are a lot stiffer. The yellows are for the race oriented drivers out there. If your car is just a daily driver, the reds should be fine. If you autocross and/or road race a lot, then the yellows might be better suited for you as long as you can handle a rougher ride.
I think the reds are about $500 and the yellows are about $725
Old May 30, 2008 | 12:33 AM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
I believe the reds are also adjustable.
Old May 30, 2008 | 04:20 AM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
OK every response in this thread is WRONG! Reds are adjustable, yellows are adjustable. Both are adjustable in REBOUND ONLY. Compression damping is fixed in BOTH. I already posted a link to the chart on tirerack.com in the other thread, on this very subject, that you all posted on, that is still up on the first page of this forum. Go find it yourselves.
Old May 31, 2008 | 08:40 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Well Ill be damned.
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
Dragonsys
Sep 25, 2015 03:51 PM
